Unerasable lines in the Pro 2001 Drawing
Newbie
Hai Friends,
I am want to ask you about a problem from Pro E 2001 drawing mode. I believe this is prevailing in the whole Pro Modelling world.
Now let me come to the point.
I am not able to Erase some Hidden lines from the drawings. My concerns are listed below.
i) I am sure that those lines are hidden.
ii) I have tried using select all option in the edge display>erase line option
iii) I have even converted some adjacent lines to wire frame and then tried to erase it... But the result is the same
iv) This not only with cross section but will all such views of complicated parts.
Please find the attached file as an example. Where this part is really complicated and to give you an idea about the complication. the size of the model is about 500 Mb. I have taken a section and most of the tangent lines have been erased but these ones.
If any of you Pro Gurus can Help me out from this It would be perfect for me. I am not sure weather this kind of problems are there with Wildfire 1.0&2.0 or not.
With Regards
Deepak K Veettil
