VARIABLE TEXT IN DRAWING TEMPLATE
Highlighted
Alexandrite
I want to add some text to each template view. But I am not able to understand how to do it using variable text.
Image has been attached below.
Highlighted
Re: VARIABLE TEXT IN DRAWING TEMPLATE
@sparulekar
Variable text will appear on customizing the symbol. Check details in article https://www.ptc.com/en/support/article?n=CS66449
Highlighted
Thank you for your response!
I want to add this type of text box in the drawing template such that they get automatically loaded in the drawing file.
Also the text can be edited in the drawing.
Highlighted
@sparulekar
Image is from template view... I don't think it will help you. If you have some pre-defined notes, you may use mapkeys...
