Greetings,
I am reading this fantastic post about exporting ansys results as a VRML file:
By following the procedure, I am able to output a .wrl file which will then open in a browser which has Cortona installed.
All the color contour information is intact.
I am also able to open the .wrl file in Pro/Engineer (WF4) and it is a complete deformed model.
However, the colors have all been reset to grey.
Is there a config option which can control this or another trick to import with all the colors intact?
