Didn't get much response from the viz topic, so trying again here. Got no response from the Community.
In CreoView 2.0 publishing, we are publishing a WF4 drawing that has shaded views on sheet 2. One of the views has what appears to be a masking of the geometry from view bounds of the other view. Item callouts in that portion of the drawing show fine, just some part details are blocked out. I opened the part in WF4 and the view bound is NOT covering the other view in the area blocked on the drawing. We are publishing to PDF. Has anyone seen similar behavior before?
