Dear All,
Is that any way to make the answer round off after calculating by the formula used :
See the attached formula ,in this formula the value came like 915.12 and in next part 915.22 ,so that in the BOM its saying as two parts with same part no.
Please suggest.
Mainsh
What do you want to round to? The nearest integer? If thats the case you can use the functions floor() or ceil() to round up or down to the nearest integer.
Dear Andy,
How to Use this while writing the relation.
Let say ,i have the formula :
L=d1,
and i want its no decimal value.
another
L1=d3
and its upto 3 decimal value .
How to do all this.
Manish
Type | Article |
Date Created | 02-Feb-2012 18:05:11 EST |
Date Last Updated | 07-Apr-2013 22:05:49 EDT |
Title | How to use round function in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric |
Description | How to use round function |
Applies To |
Cause | |
Resolution |
