I do not understand the use of flatten form command's existence..Flatten form doesnt give you any dimension added into sheet metal just as we get in flatten sheet. If we want to flatten a sheet with punches,we can do it by supressing punch form even...then no use of flatten form...Can anybody help me out what i am missing~~~~~~~~~~
You're not missing anything. There is really no intelligence in flatten form. It just allows you to stage the punch steps.
Thanks a lot for replying sir
