Warning : A models displayed dimensions MAY NOT match it's models true size.
This could be a Pro/NC nightmare.
If you open a pre WF5 model in WF5 and modify a dimension properties, lets say 1/8 so 0.125 and you modify dimension digits from 3 to 2, the model will not need a regeneration (like in WF3) and the dim will show 0.13 but the model will stay at 0.125. Very scary!This is due to the new WF5 configure round_displayed_dim_values which is defaulted to yes in WF 5.0!
