Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Can someone please explain to me how to change the color of an imported solid in a model to be different than the default color of the rest of the model. I can't seem to do this in Wildfire 5. I am hoping that it can still be done, or I am going to lash into PTC about removing functionality. I had a mapkey that did this previous to W5.
CONFIDENTIALITY NOTICE: This email along with any attachments contains proprietary information, some of which may be legally privileged. If you are not an intended recipient of this email, you must not disclose, copy or take any action in reliance of this transmission. If you received this email in error, please contact the sender and permanently delete all copies of the email and any attachments.
