I have dimensions in Creo drawing file. How can I identify X and Y co-ordinates of dimension present into creo file?
Regards
Ketan
Ketan,
X & Y can have for points not for dimensions or notes in drawings.
Correct. I am able to have X & Y coordinates for Point. But, I am not able to understand how to identify X and Y coordinates of Dimensions?
What about hole tables? If your desired featers are holes, it´s the best solution.
See PTC forum for more informations about hole tables.
Milan,
Thank you for this information. I am concerned about Dimensions...
Ketan,
