a hatch in Annotation
Not applicable
How can I add a hatch to my annotation drawing?
Re: a hatch in Annotation
Use the hatch command (icon in Annotation above the printer icon) Easiest way: Create hatch by polygon; Draw a closed polygon and it will be automatically filled with hatch
If you create a section view in Annotation, it is hatched by default.
Adding hatch by face is easy as well (Button is right from the one of 'by polygon') : Click an edge of an closed contour, then click inside the contour.
