awesome appearance.dmt
Newbie
Looking for an awesome appearance,dmt if anyone wants to share it. A butt load of colors would be way cool.
7 REPLIES 7
RE: awesome appearance.dmt
Here is one with a few hundred colors, mostly from an HTML color chart.
Pretty surethey're mostly from this site...
http://www.tayloredmktg.com/rgb/
In Reply to Rex Snider:
This is in the older color.map format, but should load.
It is the Pantone colors.
Thank you,
Ben H. Loosli
USEC, INC.
Now that the subject of colors cropped up again, what texture options
are most users using?
A quick search reveals:
Bump Map: A one-channel texture map that creates the illusion of surface
roughness.
Color Texture: A three-channel texture map that consists of red, green,
and blue values.
Not sure how much a "butt load" is, but here is one that has about 250 colors with labels. That may qualify as a J-Lo size of colors.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
DXF Mapey
Does anyone have a Mapkey that will create a DXF for each respective sheet of a drawing?
I have one now, but was unsuccessful in making it change sheets. I currently run the Mapkey, then manually switch sheets, repeat...
Doug Pogatetz
Mechanical Design Engineer
Northrop Grumman Corporation
DXF Mapey
Doug,
If you have control over internet explorer permissions, this would be
something easy to do with
The weblink api or VB api in pro/e.
Unfortunately our browser permissions are severely restricted here so we are
not able to use weblink or VB api's.
Don A
RE: DXF Mapey
The mapkey (from WF4) in the attached MDXF.txt will do up to 15 pages w/o interaction. If you have less than 15 you need to "cancel" twice as it finds the last existing file... It's not perferct but it is relatively easy...
