both text and dimension in a relation
FredrikIversen
Hello
We have a parameter for the dimension. We call it "dim_drawn" and it shows in the drawing.
I want to show this in the drawing "30x20 L=100"
"30x20 L=" types manually but I want have 100 automatically from the model.
Can anyone help me with this problem?
7 REPLIES 7
Is the 100 coming from a parameter? Have you tried &parameter_name, where that is the name of the parameter you are using?
Dale_Rosema
(To:Dale_Rosema)
Or if it is coming from a dimension, you could use &d32 where that is the name of the dimension that you are getting the value. To get the name from the part or assembly, go to Info->SwitchDimension and the dimensions will now show with the dimension names instead of the values. Hope either of these helps. Dale
If it's a model dim, you can also edit the dim properties and add the "30x20 L=" test to the dim itself. Then it'll show in the model and the drawing.
LinkedIn
If I understand you correctly, the parameter 'DIM_DRAWN' is what gives you the dimension, in this case 100.
So to get a note to show "30x20 L=100" , you would type:
30x20 L=&DIM_DRAWN[.0]
The '[.0]' part makes it show the value of the parameter with 0 decimal places. If you wanted 100.0, you would put '[.1]'
I hope this helps
Cheers,
John
I mean like this.
We type the sizes in this parameter, for example 30x20 L=100
In the drawing it would show 30x20 L=100 in the bom-list.
I want to type "30x20 L=" manually and get the 100 from the model (its the length of the part, for example d4)
I would do this in som flexible parts that only varies in the length. Then it always would be correct dimension in the bom-list.
I hope you understand
Try this relation:
Dimmensions in model:
A=30 (parameter or dimmension from model)
B=20 (parameter or dimmension from model)
D3= dimmension of lenght (variable)
Relation:
PARAMATER="L_profile "+itos(A)+"x"+itos(B)+"; L="+itos(D3)
Result after regeneration:
PARAMETER=L_profile 30x20; L=500
Than call PARAMETER in your BOM.
Legend:
1) ITOS == convert INTEGER to STRING
2) "string text" == write general text between QUOTATION MARK
3) don´t forget input + mark betwwen
TIP:
If you need more space between letter put +" "+ it will make a free space.
Hope it will help you...
Thank you.
That´s exactly what I want.
