box around text?
A.DelNegro
box around text?
I would like to add boxed numbers to a drawing to indicate dimensions to be inspected. I know I can add @[ to start the boxed text. What do I add to stop it?
If I put the @[3 before the dim I get this
[cid:image002.png@01CF5F9E.892F1770]
If I put it after, I get this.
[cid:image003.png@01CF5F9E.892F1770]
What I really want is the number in a box in front of the dimension.
T
10 REPLIES 10
You need to add @] to stop.
Mehmet Ali PISKIN
ASELSAN Inc.
MGEO IR Systems Design Department
Cankiri Yolu 7. km
Akyurt 06750
Ankara / TURKEY
+90 312 847 5300 / 4580
I believe all you need to do is end your boxed text with @]
Ex. @[boxed verbiage@]
~Doug
@[3@]@D
[cid:image001.png@01CF5F9F.35CFBFC0]
Mike Brattoli
Moen Incorporated
Global Product Development Process Management
Administrator - PLM
Is there a list for all the "@" functions?
I know:
@[ box start
@] box close
@o omit - (bad for people who cheat dimensions.....)
@+ superscript
@- subscript
Any compilation out there other than trying them all?
Scott Cserep
I believe the @O needs a capital "O"
~Doug
dpruitt
(To:A.DelNegro)
You could just check the inspection button in the dimension properties. Any text you add will be included in the "racetrack".
[cid:image001.png@01CF5FA0.56AA2130]
David Pruitt | Mechanical Design Engineer | ASCO Power Switching and Controls
Emerson Network Power | 325 Welcome Center Boulevard | Welcome, NC, 27374
T 1-336-731-5027 | TF 1-800-800-ASCO
www.EmersonNetworkPower.comwww.AscoPower.com<http: www.ascopower.com&quot;=">http://www.emersonnetworkpower.com/>www.AscoPower.com<http: www.ascopower.com<=" a=">
A.DelNegro
(To:A.DelNegro)
This worked. For some reason I kept using @[ to try to close it, duh!
@# will end a superscript or subscript
Chris3
20-Turquoise
(To:A.DelNegro)
There is a thread with a bunch of the options here:
