Combined States are sort of the output of Model Based Definition / 3D Annotations. Once you have a Combined State set up, it's easy to use it as the basis for a drawing view. (Unfortunately, using it to define a drawing view does not display the 3D Annotations associated with that state in modeling mode.)
Combined States currently do not support Style States in drawing mode. And I can't remember if they support Layer States as well.
David R. Martin II
Senior CAD Application Specialist
Amazon
Hi Lance,
The configuration option auto_show_3d_detail_items is set to yes by default, and when I've created a drawing view using a combined state, the 3D Annotations are not being shown by default. I need to test this some more to figure out the nuances; perhaps the combined view is not using one of the saved views as you have pointed out. But ideally, I'd like to select a combined state for a view and also see all its 3D annotations (except of course for any shown dimensions displayed in another view).
David R. Martin II
Amazon
