create bom with 1st item being 10 and 2nd item being 20 and so on and so forth
skantorski
1-Newbie
What do I modify to start my BOM  drawing to start with 10 instead of 1? 2nd item would be 20 instead of 2? and on and on.
Thank you.
1 ACCEPTED SOLUTION
Steven,
if you are thinking about repeat region, then you can:
>>> add following relation into the repeat region:
myindex=rpt_index*10
/* rpt_index written in relation correspond with parameter rpt.index entered in repeat region cell
>>> enter following parameter into repeat region cell
&rpt.rel.myindex
Martin Hanak
Martin Hanák
3 REPLIES 3
I think you're in the wrong topic. You should check out Assembly management or something like that. Customization is about C / C++ / Java and so on, extension programming.
Br,
Eike
Sorry. New to the site.
Steven,
&rpt.rel.myindex
Martin Hanak
Martin Hanák
