Hi All,
I want to revisit this subject in hopes that some new development from PTC or a clever work around was found to allow users to include other dimensions into a feature callout. When this setting is enabled it allows users to create/modify drawings of a model with out saving information onto the model. This is great for manufactoring to get information they need and allow the design files to be secured with out rolling to a new version/state everytime someone from manufactoring wants to create or edit a print for a mfg process. The downfall is that you can not call out a diameter of a hole using a shown or created dimension and then reference another dimension like a counterbore diameter with in the dimension. Example would be to have a Dia. 125 with a C-bore of &d1234 or &ad1234. So, anyone have any solutions or work arounds?
James
