creo 3.0 Reverse arrows dimensions
gpontremoli
In creo 2.0 and all previous versions, during the dimensioning operations, it was possible to reverse the position of the arrows, with a click on the right mouse button.
In creo 3.0 this is not possible, you have to confirm the location the dimension, and re-select the dimension and right click, reverse the position of the arrows.
This is because during the dimensioning, the click of the right mouse button brings up a menu of options dim.
The solution is to use a quick click of the right mouse button to swap the dimensions, and a slow click to bring up the menu.
This needs to be a product idea so we can vote on it.  It's a serious step backward in productivity on Creo 3 and the method you've suggested is the method of using the RMB in other areas of the software, so precident is set.
Creo really needs some consistency in the UI, which reminds me (shameless plug alert) of this product idea of mine that could use some more votes:
Consistent Behavior for Middle Mouse Button
LinkedIn
