crossed text in table
jsantiago
Hi everybody,
I need write a crossed text in a drawing, like a note, table etc..
Are there some way to do, whithout having to put a line?
like that  crossed line
thanks in advance
regards
What Creo software are you using?
This area is for Creo View, Creo Direct, Creo Sketch and other smaller Creo packages.  If you're using Creo Elements Direct or Creo Parametric, you'll get more help in those specific areas.  Someone can move the thread for you, but we'll need to know what package you're using.
LinkedIn
jsantiago
(To:dgschaefer)
Creo Parametric Thank you
I notified a moderator to move the thread to https://community.ptc.com/t5/Detailing-MBD-MBE/bd-p/detailing.
I don't think there is a built in strike through function in Creo Parametric, but I'm not certain.
LinkedIn
strike through functionality is not available - see https://www.ptc.com/en/support/article?n=CS210308
To get strike through text, you have to change text font - see images on https://community.ptc.com/t5/Detailing-MBD-MBE/Strikethrough-a-text-in-proe-drawing/td-p/58858 page.
Martin Hanák
