dimenion disappears when referenced in a table with &str
Newbie
I created a dimension on a page. I renamed the dimension to something I could remember - height. I then created a table and entered &height. The field fills but the dimenion disappears. How do I get the dimenions to show as well.
RE: dimenion disappears when referenced in a table with &str
Yes, it's normal. I suggest you to create a new parameter in drawing (PARAM_DIM_1), then a relation like PARAM_DIM_1 = ad## in order to link the parameter to dimension. So in the table you can write &PARAM_DIM_1 and the dimension will remain in the drawing view. Hope clear.
Or throw a driven dimension on it so you dont have two driving dimensions. That way one is a master and the other a slave.
