drawing layers from model
didriek
6-Contributor
Hi all,
I'm busy making drawings and the layers of my model are all ok/hidden curves, quilts....
But when I make my drawing views the setting to take over the model layer status is not set.
So, I take the option to copy the status from the model
BUT
It does not automatically takes the layerstatus of the part/assy I make the views from (active drawing model), it asks me to select the assy/part to copy the status from?
And when I select the assy it does nothing
So each time I need to set all drawing layers manually again, and save because I cant copy it from the active model
How annoying
didriek
6-Contributor
(To:Patriot_1776)
I have found what I was looking for:
In the layer tree I 'right clicked' and had the option to 'copy the status' from but that failed a little on assemblies and often I forgot to save...
BUT
What I was looking for was under 'layer tree settings' not under layers
There is the last option 'drawing layer status' where you get the Wildfire window: LAYER STATUS CONTROL
Where you can mark/unmark 'ignore display status of layers in the model'
>> I unmarked because often my layers are nicely set in the model (except if I would need something different on my drawing)
I have not found an easy way to make layers work well in drawings. The second best thing is assigning layers specific to the view. ....and remembering to save their status.
Hopefully someone will post a good tutorial explaining exactly how layers are meant to be used.
Patriot_1776
(To:didriek)
I would not copy status from model. Model changes can then have unintended drawing changes. For my drawings I have the following in my .dtl file:
draw_layer_overrides_model NO
ignore_model_layer_status YES
You can set the layers in the drawing in general, and that will change all the views (best/easiest option if possible). As Antonius mentioned, you can also choose to have a specific layer setup for each individual view if wanted. The caveat is that you can't put that view back under the "general" layer control. You can copy the settings from the general view, but it must be done every time, and for each view. That would be a valuable enhancement. Also as Antonius mentioned, make sure you save. Layers can be kind of a PITA, and there are some bugs.
I have created start models that use layers with rules, which work very well. Especially when converting models that don't have our layer structure. I've attached an excellent .ppt demo.
didriek
6-Contributor
(To:Patriot_1776)
BUT
Actually, you can put a drawing view with independent layer status back under general drawing control. In Creo 2.0 it is the "drawing dependent" command under one of the pull-down menus in the layer tree. It was around in Wildfire also...but buried even deeper I think.
