exporting drawing
jsarkar
1-Newbie
exporting drawing
When we export a drawing from CREO to AutoCAD, it is in either model space or paperspace with specified scale as in CREO. My customer wants AutoCAD drawing where the object will be in model space ( 1:1 scale) and the drawing in paper space. Is it possible to export from CREO to AutoCAD in this manner?
1 ACCEPTED SOLUTION
aminati
(To:jsarkar)
I think is not possible. You can export a drawing in model space or in paper space or a sheet in model space and other sheets in paper space.
Try to export in model space and then in autocad put it in paper space...
Best Regards
AMinati
3 REPLIES 3
aminati
(To:jsarkar)
Best Regards
AMinati
StephenW
23-Emerald II
(To:jsarkar)
I never trust my scale when I export out of Creo. If I have access to the software I am exporting to, I will check the scale and adjust if necessary.
I have confirmed it through tech support that this is not possible.
Thank you for your interest.
