exporting drawings to ACAD with embeded images
Newbie
OK, I had a similar question earlier with only one response as to how to remove the flicker from a bitmap image that was imported in a pro/e drawing. The suggestion was to use a .gif or .tif. Unfortunately, everytime I try to use a format other than .bmp I am unable to view the image in the drawing. Basically that suggestion didn't help that problem. However, now I have another problem somewhat related. From time to time we need to export our pro/e drawings to ACAD for various vendors. When exporting the drawings with the embeded .bmp images the embeded images do not translate. Now I'm either forced to go back and redo the formats with sketches of the company logo so it will export(and not be as pretty), or we have to import the company logo on all drawings that we export to ACAD or someone helps me out and gives me an easy solution as to how to export the drawings with the embeded images into ACAD? 🙂 I have a feeling I won't like the answer to the later solution. Thanks in advance.
