how do I create a break out view?
Curtis
how do I create a break out view in a Creo Drawing view?
1 ACCEPTED SOLUTION
StephenW
23-Emerald II
(To:Curtis)
Create a cross section in the model where you want the breakout to be. Then, in the drawing, use the section as a local section (instead of full x-section).
3 REPLIES 3
StephenW
23-Emerald II
(To:Curtis)
Curtis
(To:StephenW)
Thank You
Good day Curtis,
Looks like Stephen's solution fixed your issue; would you please take the next step and mark his answer as "Correct Answer?"
This way others reading the thread know there is a solution, in addition, it makes the solution easy to find.
Thank you,
Toby
