how do I create a break out view in a Creo Drawing view?
Create a cross section in the model where you want the breakout to be. Then, in the drawing, use the section as a local section (instead of full x-section).
Thank You
Good day Curtis,
Looks like Stephen's solution fixed your issue; would you please take the next step and mark his answer as "Correct Answer?"
This way others reading the thread know there is a solution, in addition, it makes the solution easy to find.
Thank you,
Toby
