how do I dimension drafted rounds on Creo 3.0?
Re: how do I dimension drafted rounds on Creo 3.0?
Yeah I guess the main problem is that it's an imported geometry and I can't really change how the part is created. I'll keep in mind your suggestions when I create my own models with similar features. Thanks for the help guys!
What is the best practice, to add the radius before drafting the two perpendicular surfaces or apply the draft and then add the radius?
You can try showing such radii after setting the drawing detail option "allow_3d_dimensions" to yes.
