how to add more colors into appearance gallery of asm template
SOLVED
Newbie
I would like to know whether there is some posibility to add more colors into appearance gallery (.dmt) of asm template so that those new colors can be used for new created parts/asms.
Thanks in advance
T.
Re: how to add more colors into appearance gallery of asm template
1. Don´t use SPACE in proengineer (Creo). If you need a space use an underline "_". (Používejte podtržítko místo mezerníku). Creo is sometimes confused from spaces in names.
Example:
V:\Creo sablony ---> V:\Creo_sablony
2. Do you use a config.SUP? It´s a "company" config with config´s options that regular user can´t overwrite. It´s is usually located on server and drive with cad admin.
It means: If your cadadmin specified a pro_colormap_path in config.SUP it will ignore your local configs.pro.
8 REPLIES 8
Hello Tomas,
what l know, there are 2 basic possibilities of adding appearances into gellery:
1. Add 1 by 1 appearances
STEP 01 - click right mose button on some coloros, that you want change
STEP 02 - edit color als you wish (change color name) --- when finished confirm OK
STEP 03 - new color was add into your project appearnaces library
2. Append / merge appearances galleries
STEP 01 - open appearnces gallery and click APPEANRANCES MANAGER
STEP 02 - click file (its a small hide button) and choose APPEND
STEP 03 - choose second *.dmt file from your PC that will be append/merge (CZ note --- připojen) to first one gallery --- confirm OK and galleries should be add
NOTE:
l´m not absolutly sure, but there can be some restriction about numbers of appearances in one gallery. l think it´s can be somewhere around 256 colors.
Hope it can help...
Hi Milan,
Thanks for your quick response.
I tried it but after the model (template_designasm in my case) is saved and opened again - my new added appearances are lost... 😞
Set your config.pro options pro_colormap_path to your default *.DMT file that should be load primary.
Are you sure it is this option? cause here is a .map extension to be changed since my appearance gallery has a .dmt...
Yes *.MAP file is an old extension and *.DMT is a newer one.
*.MAP had been use upto ProEngineer 3, than it was renamed to *.DMT (don´t know exactly).
Examples of *.DMT and *.MAP are attached. Try to import them.
Function is the same...
Ok, but it remains the same although i changed the setting even in all configs.pro according to creo information window. Please see a pic:
Example:
I changed the space with underline but the problem was in another config that i did not change....
thanks for help.
B.R.
