how to edit text in nested repeat region empty cell
ptc-5748551
thank you, Joey.
but i failed to open the link, could you please give me an other link about it?
thank you again!~
Seems goofy, but add the bold text shown below.
Also, I would recommend changing the current working directory to your outdir, passing only the
file name as the FileName parameter of Export, and then returning the user to the previous working directory when you're done. The reason for this is the FileName parameter for Export only accepts 40 characters. You could run into an issue if you have a many characters in your working folder path.
Dim dwginstructions As IpfcDWGSetupExportInstructions
Dim exportInstructions As IpfcExportInstructions
Dim outdir As String
dwginstructions = (New CCpfcDWGSetupExportInstructions).Create()
exportInstructions = CType(dwginstructions, IpfcExportInstructions)
outdir = asyncConnection.Session.GetCurrentDirectory() + model.InstanceName.ToLower + ".dwg"
model.Export(outdir, exportInstructions)
i have the same problem and still no solution.
did the code above work for you?
