how do you erase a geometrical tolerance from a dimension in a drawing
easiest:
select the annotation tab
right mouse the gdt then select pick from list, select the gtol
hit delete
thanks!
Hi Doug,
If that solution worked for you, could you please mark it as the Correct Answer, for future reference and to help close the loop.
Amit
