how to report a number with conditionally-determined decimal places in a drawing
Marble
I am experiencing a problem with reporting a number parameter (in my case a parameter of mass) with specific decimal places in a drawing.:
- I would like to plot the parameter with 1 decimal places if the mass is higher or equal to 1 kg.
- If instead the mass is lower than 1 kg, I would like to report it with 2 decimal places
I tried to set a conditional script (in the relations field) with functions like "if...ceil(),floor()" : but the problem is that in the drawing cell where I report the mass, I cannot set a conditional-formatted number of decimal places. I can set only 1 or 2, fixed:
and therefore when the mass is higher than 1 kg (for example 2,6 kg) and I set 2 decimal places in the cell property window, it reports for example 2.60 kg (with a useless zero).
(and vice-versa if I set 1 dec. place with a mass lower than 1 kg, the system cuts out a decimal place).
thanks
22 REPLIES 22
Re: how to report a number with conditionally-determined decimal places in a drawing
The only way I know to do this is to create a single cell repeat region, add the appropriate relations to convert the mass to text, and then manipulate accordingly.
The repeat region parameter will initially be set to &mdl.param.value and a "by rule" filter will need to be added for your specific mass parameter. Something like &mdl.param.name == massa. This should display only the value for the mass in the repeat region. Next, add relations to the repeat region:
IF mdl_param_value >= 1
IF FLOOR(mdl_param_value) == FLOOR(mdl_param_value,1)
WEIGHT = ITOS(mdl_param_value) + ",0"
ELSE
WEIGHT = ITOS(FLOOR(mdl_param_value)) + "," + ITOS((FLOOR(mdl_param_value,1) - FLOOR(mdl_param_value)) * 10)
ENDIF
ELSE
IF mdl_param_value >= 0.10
WEIGHT = "0," + ITOS(FLOOR(mdl_param_value * 100))
ELSE
IF FLOOR(mdl_param_value,2) == 0
WEIGHT = "0,00"
ELSE
WEIGHT = "0,0" + ITOS(FLOOR(mdl_param_value * 100))
ENDIF
ENDIF
ENDIF
Finally, switch the repeat region cell parameter to point to your newly created relation parameter (WEIGHT in my example). &rpt.rel.WEIGHT
Note: The sample relations above always round down. You would need to modify them with additional IF statements if you want to round up and down.
Hey, I do a lot of this type of stuff for building part numbers, descriptions and the like using dimensions. This is the slightly more tricky way I have to get floating point numbers into text strings, with decimal places the way you want them:
IF FLOOR ( number ) < 1
WEIGHT = "0," + EXTRACT ( ITOS ( 100 * ( number + 1 ), 2, 2 )
ELSE
WEIGHT = ITOS ( number ) + "," + EXTRACT ( ITOS ( 10 * number ), 2, 1 )
ENDIF
The addition of 1 to "number" in the first IF clause ensures that multiplying it by 100 gets a number of the format 1XX, so extraction of the two digits of interest is guaranteed.
As stated in Tom's reply, you've got to add a bit of logic if you want to round up or down.
What I wonder is how a program can be more than 20 years old and still not have the functionality built in for converting floating point numbers to strings.
thanks for your suggestions, they were both useful.
I inserted this script (massa_disegno is the parameter to print in the drawing):
if pro_mp_mass<1 & pro_mp_mass >= 0.0005
massa_disegno=itos(1000*pro_mp_mass) + " g"
else
if pro_mp_mass-floor(pro_mp_mass) < 0.05
massa_disegno=itos(floor(pro_mp_mass)) + ",0" + " kg"
endif
if pro_mp_mass-floor(pro_mp_mass) >= 0.95
massa_disegno=itos(ceil(pro_mp_mass)) + ",0" + " kg"
else
massa_disegno=itos(floor(pro_mp_mass)) + ","+ itos(10*(pro_mp_mass-floor(pro_mp_mass))) + " kg"
endif
if pro_mp_mass < 0.0005
massa_disegno="< 1 g"
endif
endif
Therefore at the end we decided to print the mass with this logic:
- part with mass lower than 1 g as --> " < 1 g"
- part with mass lower than 1 kg but higher than 1 gram as --> " xxx g "
- part with mass higher than 1 kg as --> " xxx,x kg "
and the script works!!
and...yes it's incredible how Creo is missing a function like this too, and above all there is no possibility to use "else if" so I have to make strange nestings!!
just for curiosity, you wrote the code in Matlab didn't you?
because if not, I guess it'd be more comfortable to use that interface in Creo instead of the default relation panel...
Bye
No, we don't use MatLab. I wrote that stuff in the relations part of Creo. And yes, as a programming language, it's pretty primitive, about the level of Fortran.
And so how did you manage to have that interface in the relations panel? (I was saying the contrary, that is it's more comfortable the interface you are using)
Oh, I think you meant to be asking Tom. I'd say he *is* using something else to write equations. Probably MatLab, but I don't know. Sorry.
yes I first asked him but probably he didn't see it yet...
thanks anyway, bye
PTC doesn't have conditional formatting. It also doesn't have a Real->String conversion, though it does have ITOS, so you could craft a set of relations to convert the Real to Whole / Fraction to String.
I think this should work, though some more effort may be required as I don't know what PTC does with INT->REAL conversions; if it truncates this works ok; if it rounds, then some extra work is required:
/*WHOLE and FRACTION are type INTEGER, MASSTEXT is type STRING
WHOLE = MASS
IF WHOLE > 1
FRACTION = (MASS-WHOLE)*10
ELSE
FRACTION =(MASS-WHOLE)*100
ENDIF
MASSTEXT = ITOS(WHOLE)+"."+ITOS(FRACTION)
