As captured picture below, how can I turn on neon effects for selected feature or dimension lines?
Thank you.
You can turn on this option by inserting the following line in config.pro
enable_selection_glow yes
Thanks to James Lim in Digitek for giving this tip to me.
Interesting... we have neon?
Highlighted? (translation?)
Interesting, I'm on creo 3 and that option doesn't show up
It is a hidden option. Just type it in your config.pro with text editor.
Ahhhh, thanks!
Does anyone have a link to creo 3 "hidden" config.pro options? the last one I have is oooooooold.
I use Olaf Corten's Search Pro/ENGINEER config.pro options utilities to find options.
**There was just a post on the system admin section about a list...Creo 4 Config Options - now .csv
That's a very interesting feature. I'm not sure I like it but I'll try it a little while to see
I just tried it, and I'm kinda diggin' it! Got a separate config_test.pro I manually load so I can switch back and forth, but so far, me likey! I also made a quick Excel file of that page with ALL creo 3 configs, so I can post that if needed.
Thanks guys!
Works in Creo 2 as well, at least in M230. Not sure how I feel about it, but I'm going to give it a shot.
I haven't used it much yet, but am liking it. These old eyes need a little more highlight.
I posted all this here at work for all the ex-SW users now using Pro/E, maybe that will eliminate SOME of the whining....
Ok, so, I wasn't able to see any change in drawing mode, though it was a quick check. where I think I like it the most, is in sketcher mode. It REALLY highlights constraints, sketched entities, and other objects well. Again, just a quick test in sketcher, but I think I like this setting!
For those that are using neon effect here are some extra neon display control options:
glow_blur_radius 1
glow_blur_sigma internal
glow_blur_type internal
glow_line_width 2
The problem with hidden configs, is that there is no explanation as to what they do. I tried the above configs, and didn't like them.
glow_blur_type:
glow_blur_radius:
glow_line_width:
glow_blur_sigma:
sigma adjustment from 0-24+
Some examples of different values when changed. Also note, I have my "selection color" set to a neon green because the magenta selection color is not as "highlighty" to my taste.
Awesome, that really helps, thanks!
