how to turn on neon effects for selected feature or dimension lines
SOLVED
Newbie
As captured picture below, how can I turn on neon effects for selected feature or dimension lines?
Thank you.
1 ACCEPTED SOLUTION
Re: how to turn on neon effects for selected feature or dimension lines
You can turn on this option by inserting the following line in config.pro
enable_selection_glow yes
Thanks to James Lim in Digitek for giving this tip to me.
17 REPLIES 17
Interesting... we have neon?
Highlighted? (translation?)
Interesting, I'm on creo 3 and that option doesn't show up
It is a hidden option. Just type it in your config.pro with text editor.
Ahhhh, thanks!
Does anyone have a link to creo 3 "hidden" config.pro options?  the last one I have is oooooooold.
I use Olaf Corten's Search Pro/ENGINEER config.pro options utilities to find options.
**There was just a post on the system admin section about a list...Creo 4 Config Options - now .csv
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
That's a very interesting feature. I'm not sure I like it but I'll try it a little while to see
Stephen Williams
