option for representation while creating drawing..
Visitor
Dear Team,
When I create new drawing with representation instead of master rep, it should ask about what rep I need to put in drawing. What option I need to set so that it will prompt desired rep to select and BOM table should shows only Rep component. Please help me.
Jitu Thakor
Tags (1)
Re: option for representation while creating drawing..
This is certainly possible.  What workflow are you employing that you're not seeing how to specify that you want an assembly rep?
I think maybe you mean the config.pro option:
open_simplified_rep_by_default yes
