Dear Team,
When I create new drawing with representation instead of master rep, it should ask about what rep I need to put in drawing. What option I need to set so that it will prompt desired rep to select and BOM table should shows only Rep component. Please help me.
Jitu Thakor
This is certainly possible. What workflow are you employing that you're not seeing how to specify that you want an assembly rep?
I think maybe you mean the config.pro option:
open_simplified_rep_by_default yes
