Sl.no | Problem | issue facing |
1 | Running of wire in both side without tangency net work | Making tangency network for the wire running in both side has the below disadvantage |
1. Flatten of harness become difficult | ||
2. Wire length short due to tangency net work. | ||
3.wire branch out dimension showing issue . | ||
4.For actual Manufacturing of harness length will become short. | ||
2 | converting to iges/Step | Unable to convert to iges/step. |
1.Pro-e getting crashed | ||
2.Some of the harness after converting only connector visible. No harness. | ||
3 | Branching | Branching with intermediate gape. |
1.Wire getting not routed. | ||
2.Wire getting failed after regenerating. | ||
3.Unable to make bundle. | ||
4.Unable to make harness as per the physical harness branching. | ||
4 | wire failure | Wire getting failed |
1. out of many wire routed one wires fails saying no net work. Start and end point same for all wires. | ||
2. Wire routing does not go up to end point . Stops in between in a spice or break out | ||
3. While auto routing - after few wire route when we try to route the other wire the existing routed wire fails | ||
4.After routing the wires and when we try to bundle wires fails. | ||
5.Routing of 300 plus wire in single short in auto routing become difficult .wires getting failed. | ||
5 | Splice | splice adding in between the intermediate gape |
1.Splice should be a part of single wire.In pro-e we add the splice in net work which make other wires also to pass through the splice which cause wire failer due to bend bend radius | ||
2. We are giving 50mm clearance between the two splice. When we add many splice in a net work wires getting failed. | ||
6 | Modification | Small modification |
1.small modification (adding wires,relocating the connector position)call for change in flatten and drawing which take long time . | ||
This time is not excepted. | ||
7 | Regeneration | 1.Auto regeneration is not happening we need to regenatre manual after wire routing very time |
2. Due to this regenration issue wire are not visible after routing. | ||
3. wire failure and bundle failure comes. | ||
8 | Auto routing | Designation of component |
1.If the model name and part name is same auto designation take place but in harness we use reference number for each component . We are using some component in more than three place . At present we are making manual.How to designated all parts with auto designated. | ||
9 | Flatten | flatten of harness |
Our harness has more than 300 wires. For flatten of harness we use manual flatten method. It taken lot of time for flatten of all wires. Auto pan in pro-e is not helping us to resolve this issue. | ||
10 | Drawing | Tables for each connector |
1.Placing table for each connector is becoming one of time consuming process in pro-e. After placing the individual table we need to releate to model with table for wires to update for each connector table. |
