problem in changing dimension
ptc-3117846
1-Newbie
Hi Folks! I got Pro/e 4.0 student version yesterday!i successfully installed the software but i have problems in "changind dimension" . 1)i am trying to double click on the dimension of a line but nothing hapens! 2)i tried to select the "modify dimensions" option and click the line.but "modify dimensions dialog box"does not APPEAR i am using WINDOWS VISA 32BIT!! do i ned to change any setting to fix this problem?? advance thanks!
1 REPLY 1
I have the exact same issue. Downloaded Pro/E Wildfire 4.0 student version and the program seems to install and open correctly. But when I try to modify any dimensions and double click the numerical text, nothing happens. I am using a Dell Inspiron 1420, centrino duo processor, vista 32-bit... Any help would be appreciated.
