"Merge" BOM balloons
mbonka
my qustion is simply. How to merge BOM balloons in drawing space? Need to "glue" the 5th position to the 4th one.
It´s useful for example for washers and screws.
See picture bellow.
Thank in any advice
1 ACCEPTED SOLUTION
Creo:
Table tab > merge balloons > follow instructions
in case above, select balloon 5 (balloon to be merged) then select balloon 4 (balloon to be merged onto)
WF4:
Table > bom balloons > merge >follow instructions as above
Note:
This works for repeat region bom balloons.  I am not sure about note/symbol balloons as I don't use them.
Please drop a note if you know if you can merge note/symbol balloons.
ron
2 REPLIES 2
Creo:
WF4:
Note:
ron
mbonka
(To:RonSt.Pierre)
l had to blinded when was looking into Balloon drop down menu .
Thanks for advice
