Need answer from someone who using schematics driven piping. It is not problem for me do it from start, but I can not understand how to update 3D piping from xml. I mean P&ID changed, new export to xml, and newly exportded xml import (reload) to update existing 3D piping (3D is done with older xml).
it is posible? what i can update from new xml?
can i update pipeline size? pipe segment size? fitting size? replace fitting?
will piping system find that some fittings was removed or changed sequence of fittings?
there is tutorials somwhere about this? (video or pdf is not important for me)
thanks for reading and huge thanks for right answer.
