show Datum target on external threads
jhall2
6-Contributor
Is this even possible? I can add a datum callout to the cylinder dimension easily enough, but THEN you can't overrite the driven dimesion to only have the thread callout. Using an added dimension to permit overriding to show the thread callout and you can't show the Datum note. Why does something this common be so problematic? Am I missing something basic here?
James
0 REPLIES 0
