[solutions] - [proesys] - Export CAD from Windchill
davehaigh
11-Garnet
Obviously if you want the drawing you would back up the drawing.
Same with export I would pick the drawing.
Why would you pick the assembly. I don't see the advantage?
David Haigh
Disconnecting from the server only changes the server registry. It doesn't do other things you might want doing.
When connected to PDMLink the open save behavior should be different than when your disconnected.
file_open_default_folder workspace
vs
file_open_default_folder working_directory
In our environment there are many other configurations that are different depending on what windchill server/cache we are connected to.
If I'm connecting to a test server to test out a windchill upgrade, I don't want to corrupt my working cache with files from that environment.
David Haigh
Thank you for all the reply's so far. Let me clarify...
I'm trying to keep CREO and workspaces out of the equation.
This user only has access to Windchill via web browser.
He can see CAD files from his browser and wants select and download so he can email the CREO part/assy/dwg/ to a vendor who does have CREO but does not have access to our Windchill.
Thoughts/Suggestions???
Eric
I remember in the past when we had some outside collaborators, they were checking out from Windchill, without going through Creo.
The problem was there was a miss match in the iteration of the files.
For example the Creo file is say A.1 in your workspace and you check it in. Windchill now says it A.2, but the Creo file hasn't changed. If you check it out without using Creo, when you bring it up Creo's going to see it as A.1.
You need the workgroup manager to make that change when you add it to your workspace.
You just asking for problems. I'll bet this is why PTC took this ability away.
David Haigh
