symbol dimension
cspinelli
symbol dimension
i cannot modify the symbol of dimension as shown in the image attached. with Creo 2.0
can you help me??
1 ACCEPTED SOLUTION
Dale_Rosema
(To:cspinelli)
Finish making the extrude/revolve feature.
The right click on the feature in the tree and select "edit" (not edit definition).
The dimensions will show up. (You can switch to the names if you like).
The select the dimension you want and the right click and go to properties.
Edit in the "Name" box.
For mine it is d3.
Thanks, Dale
12 REPLIES 12
Dale_Rosema
(To:cspinelli)
Christian - No image attached.
Thanks, Dale
cspinelli
(To:Dale_Rosema)
Now?
cspinelli
(To:cspinelli)
not yet,
Dale_Rosema
(To:cspinelli)
Try this if you haven't. In the first image, click on the camera icon:
Then click on the "browse" tab and find your image. Then click on "insert image".
See if that works.
Thanks, Dale
Dale_Rosema
(To:Dale_Rosema)
You want rename the dimension or you want to put text in your dimension on your drawing instead of a number?
cspinelli
(To:Dale_Rosema)
i want to replace the symbol dimension so i can use it in a family table column
Dale_Rosema
(To:cspinelli)
You can use it in a family table column without have to rename it.
While in your table, add a column, then click on the "Dimension", click on the feature/component where the dimension is located. The dimensions for this feature/componenet will show on the screen. Click on dimension for which you want to have a column and it will be added to the table.
cspinelli
(To:Dale_Rosema)
yes, i know that, but i have already an excel file with dimension named with letters and so i have to rename the files with those letters in order to avoid mistakes
Dale_Rosema
(To:cspinelli)
For mine it is d3.
Thanks, Dale
cspinelli
(To:Dale_Rosema)
thank you! you saved me!
Dale_Rosema
(To:cspinelli)
Hey Christian,
You should mark the answer as correct instead of helpful for those who follow behind, search and find this thread.
Thanks, Dale
cspinelli
(To:Dale_Rosema)
done!
