I am converting old wildfire border formats into creo 2.0 for drawings, but most text show small in print out PDF. I increase font size that shown out box in format and out of control in PDF.
When saving the PDF try selecting the stroke all fonts option on the content tab. Or you can use the config.pro setting "intf2d_out_stroke_text" set to "all".
if formats/drawings contain TrueType fonts in texts, then set Use TrueType Fonts option.
If formats/drawings contain ProE fonts in texts, then set Stroke All Fonts option (in this case you have to set pentable properly).
Martin Hanak
Thanks a lot, I will be careful to use "Save As > Quick PDF" .
