tolerances in drawing
SOLVED
Newbie
in drawing there are many ways for displaying tolerances in drawing , i want to display tolerances to be like tol1.jpg not like tol2.jpg or tol3.jpg
all pic were attached
Re: tolerances in drawing
Yes, it is an old drawing option available in Creo 2.0 as well. Make sure your are checking this in drawing options not in config options (File > Prepare > Drawing Properties > Detail options > Change)
9 REPLIES 9
Just curious as to why you didn't just attach the jpeg images directly instead of putting them in a .rar file. I generally don't open .rar files unless I am absolutely certain I know the contents.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Compressed file formats are blocked by corporate firewalls. I can not open .zip or .rar files.
when i tried to put the image directly the massage ( this image type is forbidden ) why i do not know
i tried all the images extensions but no new
All,
tol1.jpg from Demac was as:
I don't think directly you can get this, however as an alternate option you can try using Plus-Minus tolerance mode and set lower tolerance to 0.0. After that blank 0.0 (lower tolerance) using drawing option blank_zero_tolerance as yes.
Result will be as:
thanks for reply but i did not find blank_zero_tolerance in drawing options ( i'm using creo 2)
I'm in Creo 2 also. It's there under the tolerances section in the drawing setup. (not config.pro)
FILE, PREPARE, DRAWING PROPERTIES, change (across from detail options)
Steve Williams
that is what i want thanks
