Normally, when you create a hole (using Hole) at the assembly level, it creates an assembly cut - the hole feature is not propogated to the part, so when you open the part by itself, it will not have a hole. Is there an option that allows IFX to duplicate this functionality?
Could you please mark this as solved.
You can set the following values for HOLE_VISIBILITY
Never mind. I found the HOLE_VISIBILITY option
