How to uninstall Implementer from an endpoint?
Level 1
We have an endpoint we wish to uninstall PTC Implementer from.  How do we do so?
Tags (1)
Level 8
Re: How to uninstall Implementer from an endpoint?
Rob:
It's pretty straight forward ...
  1. Shut down the remote comms daemon using the ICOMCTL command.
  2. Delete the receiver library (PTCIR is the default library name).
  3. Delete the MWIPROD user profile.
david
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
Level 1
I did these steps:
ADDLIBLE MKSIR
ICOMCTL SDPRC(Y)
RMVLIBLE MKSIR
WRKLIB LIB(PTC*)
  • (Cannot find object to match specified name.)
WRKLIB LIB(MK*)
  • Library     Attribute
  • MKSARCH     TEST
  • MKSIR       PROD
Deleted them.
However, when I went to delete MWIPROD it owns numerous objects.
  • /Implementer/MKSIR/...
  • /MKS/Implementer/...
  • Object                Library       Type      Attribute
  • IMA053003             QSYS          *LIB      TEST
  • IM0855004             QSYS          *LIB      TEST
  • IM7555001             QSYS          *LIB      TEST
  • IM9030003             QSYS          *LIB      TEST
Just delete all these too?
Level 8
Yes.
Level 1
Ok.  Done.
Thank you.
