Hi, I have a problem in lauching thingworx through tom cat.I guess its because when the thingworx war file is copied into the webapp,the extensions inside the thingworx folder are not generated properly.Only 4 extensions are generated.How could i solve this??
Hi, I think this discussion is on the wrong position. Or has your question something to do with IFX?
Oli
I am not aware of IFX. Problem is when i launch thingworx in tomcat it shows 404 error-content not found. what might be the cause and solution for it?
Move this post to the IoT Board, please.
