Im new to 3d drawings, I have a solidworks IGS file which I can open in wildfire 4 but, when I try to then change to a DWG it wont let me. Is this because of dimensions not on the IGS file?
I appreciate any help on this matter
Sean,
It won't let you reference the IGES file? You should be able and probably need to save it as a ProE format before using as a referenced part model in a drawing.
You should be able to use it for drawing after saving as a .prt file ash make drawing dimensions as reference dimensions.
Whomever you got the IGES from can try a Save as ProE file from within SolidWorks to get a ProE formatted dumb solid (Feature Tree will not come accross however).
Michael
