I need your help
The standards of the Mold Base in the Brazil are different of the European suppliers.
How do I create a copy of the complete mold base (eg Futuba) and change the dimensions?
(Example: Distance between columns, distance pin return, etcetera).
You would have any instruction or video material to help me?
Thank you for your help
Hello Mauricio,
Have you ever used the Moldbase Editor in EMX. This is a tool to manipulate the moldbase data that is provided by EMX.
Okay, next Step: What you would like to do is adding a completely new supplier which is maybe called “DME Brazil” maybe? ( I have seen a supplier like this in some other customers configs)
We will copy the existing “d-m-e” data and rename it “d-m-e_brazil”
Now you already have a new supplier showing up in the Moldbase Definition Dialog and you can also manipulate the values of the new supplier with the Moldbase Editor
The values of the suppliers “d-m-e” and “d-m-e_brazil are now completely identical.
It is up to you what you are doing with the “d-m-e brazil” values.
Here is a quick overview of the mold base editor functionalities:
Adding new suppliers is a big project and be careful with the plate values, otherwise it may occur that customers will order plates with wrong sizes.
Have a nice day,
Thomas
