Is there anyone that can explain the syntax for "pfcSolid.Solid.CreateUnitSystem" and more specific if I want to create a new unit system of type:
"mm, g, C" and have no luck with the pfcUnits.Units sequence
CreateUnitSystem (String Name, UnitSystemType Type, Units Units)
String Name --> No Issue
UnitSystemType Type --> No Isssue
Units Units --> How should the sequence look like?
Thanks in advance!
Cheers
Rafael
