can anyone help me in adding a table, in creo direct drafting?
In creo direct modeling, we can add a table when the BOM is active. can we add a table without a BOM?
Do you know what is a macro on Drafting? If not, it is a simple to use programming language intregrated in Drafting.
The macro I propose will read a csv file and write for each cell a text in the right position on the drawing. See images for example.
If necessary, the vertical and horizontal lines can be added.
The reverse operation can even be done: from a table of text, a csv can be created (same images for example!).
Could you please tell a little bit more?
If it is without a BOM, what is the source of the table?
THANK YOU, Kotom-Eng
Not for adding BOM, For general purpose.
For example we can add related data in to the table.
Could a macro writing in a table texts from a csv file be helpful?
Could you please explain more? am a new user.!
Thank you,
Mr. Kotom-Eng
I have update my web site with two macros which could be of interest for you: draw a table from a csv file and vice versa
You can download from:
http://kotom.eng.free.fr/drafting%20tools.php
Hope it helps. Do not hesitate for any comments.
