Hi all.
How do I create an arc length dimension and add the symbol to the dimension text?
I need similar to the 250 dim in the attachment.
sorry just realised i've posted in the wrong section...should be in Parametric
See
https://community.ptc.com/t5/Drafting/PTC-CREO-ELEMENTS-ARC-LENGTH-SYMBOL-ADDITION/m-p/857292
Thanks, how do you create the actual 'circular' dimension - the '35' shown in that example?
I can only get a horizontal dimension
what version of Creo is that?
it looks nothing like mine
Any version of Modeling.
By the way, are you speaking of "Creo Elements Direct" or "Creo Parametric"?
